JD 4600 will not crank
   / JD 4600 will not crank #1
zoom3x
When this first occurred at 1,085 hours, I did all the electrical diagnostic checks until I got to the Diode Block which failed. I got a new block and the tractor started right up. After two hours of run time it again would not crank. Diode Block failed the continuity tests so I took it back to the dealer and they replaced it with another new one. This time I checked the new block for continuity and if failed too. I installed it anyway but the tractor still would not start.
After much internet searching to no avail I gave up. After about two weeks I got time to dig into the checking again and decided to try the starter. Lo and behold it started fine and then worked ok a number of times during six hours total run time. Today, after using the tractor for two hours and stopping to change a blade, it once again would not crank. Help, please.
Thanks,
Larry
   / JD 4600 will not crank #2
Don't remember the wiring set up on your tractor but I've been told that diodes will burn out from too high a current (short circuit) or too high a voltage (voltage regulator problems)
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
2015 John Deere 6150M (A50120)
2015 John Deere...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2003 Ford E-350 16ft Box Truck (A50323)
2003 Ford E-350...
Cub Cadet 7254 Compact Tractor (RUNS) (A50774)
Cub Cadet 7254...
