JD 4600 Temperature Gauge - Replacement
   / JD 4600 Temperature Gauge - Replacement #1
quid_non
Greetings All!
My 4600 temp gauge finally bit the dust - was acting erratically for some time but now the needle is pegged to the red zone and won't move (even when the tractor is off). I have seen a few posts here on this and would just like to replace the gauge and not the whole console. Will a standard automotive temp gauge work fine? Will I need to replace the sending unit also or can I just tap into the existing unit (electrical). If I need to replace the sending unit any idea as to the thread size and pitch? Any advantages of a mechanical vs. electrical unit?
Thanks for the help!!
   / JD 4600 Temperature Gauge - Replacement #2
I've replaced a few water temperature gauges with after market ones and in every case, I use a mechanical gauge instead of an electrical one. For me, I think it's more accurate and reliable. I don't have a brand or anything to recommend, the last one I bought was a few years ago, and I just bought the one on Amazon with the best rating and number of reviews.
   / JD 4600 Temperature Gauge - Replacement #3
I have 1 out of the original cluster thst works. my hr Gauge quit working. so I replaced the entire cluster.
1986 GMC Top Kick Grain Truck (A50514)
1986 GMC Top Kick...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
