JD 46 Subframe Question
   / JD 46 Subframe Question #1
keeney
Veteran Member
Minnesota
JD 4100 HST
I am thinking about getting a JD 46 BackHoe for my 4100. I am concerned that so much of the 3-point and MMM stuff needs to be taken off and on to swap between mowing and backhoe.
I spent some time looking at the drawings on www.JDparts.com and it looks like the subframe bolts on to the remainder of the hoe about a foot back from the rear PTO housing. I am wondring if it might be possible to re-engineer the backhoe and subframe so that the subframe could be left on the tractor and have the hoe come on and off with a pinned arrangement or some other easy-to-connect mechanism at the point where it bolts together.
Questions for somebody who has one:
1. Does it look at all possible that the factory subframe may be able to be left on and still get the 3-pt arms, MMM linkage, and MMM to function?
2. If not, does it look like the subframe may be able to be moderately modified to accomplish this? On the drawings, it looks like there may be an issue of space on the shaft that holds the 3-pt arm between the PTO housing and the wheel-end of the axle housing.
3. If neither of those approaches look viable and it will require a whole new subframe design, what about clearances for the 3-pt lift arms between the non-sub-frame portion of the hoe. Is there space for them to sneak out, perhaps if angled up, down, or spread wide enough?
This may seem like a stupid plan, but for this combination to be convenient to use for landscaping, planting trees, irrigation and drainage digging, I also need to use the mower every week to cut the grass. If the hoe and mower are unable to play nicely together, then I would be condemmed to always having the wrong implement on the machine and mowing the grass sounds like it would take an extra half hour messing around removing the hoe and adding the 3-pt stuff, etc.
- Rick
   / JD 46 Subframe Question #2
I just got a 46 hoe a week ago and honestly haven't had a chance (work & weather) to look it over that close yet. I want to play around with removing and putting it back on but not until the weather is a little better. If you do not get some answers before I will let you know. /forums/images/graemlins/smile.gif
   / JD 46 Subframe Question #3
I have the 47. But I also have to swap the 3 point arms.
When I found that out, I about fainted.
OK, get over it. It takes 5 minutes. Its terribly easy.
Please don't modify the frame until you've lived with it.
You will love it kust as much as you wish I'd shut up.
I will, gotta go, 5 minutes from now my hoe will be off and a few minutes later my new attachment will be in place.
But the MMM is a pain all by itself to take on and off, so for smaller chores with the hoe, I would want to leave it on.
Besides, the 'bota setup can be run with the mower and hoe both at the same time. Makes me feel a bit like I picked the wrong color.
I did call and ask around on prices. With the Power Beyond and folding ROPS, one dealer wanted $6300. Pretty steep to stay all green.
- Rick
   / JD 46 Subframe Question #5
I just paid $5400 (part of package) for my 46 hoe...
   / JD 46 Subframe Question #6
</font><font color="blue" class="small">( But the MMM is a pain all by itself to take on and off, so for smaller chores with the hoe, I would want to leave it on.
- Rick
Oops, that IS a pain,
ow everything I said about my 47 still holds true. I paid 4800.00 for it. I would look at trading before paying that premium for an add on 46.
)</font>
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
Bobcat 22in. Excavator Bucket (A53117)
Bobcat 22in...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
