JD 4555 3 point won'
   / JD 4555 3 point won' #1
NealKrueger
Bixby, OK
John Deere 5520
I'm having trouble with my JD 4555 3 point won't lift. Any ideas?
   / JD 4555 3 point won' #2
Welcome to TractorByNet....
Three Point is Down & Won't Go Up At All.
The first thing to check if you have a loader on the tractor is if the loader is still working. This will rule out a pump problem. If the loader is working you can move on to the next paragraph. If the loader is NOT working then there is something wrong with the pump (normally caused by unhooking the hoses while the tractor is running which dead-heads the pump) or a problem with the oil supply (out of oil, dirty filter or screen?). You may need to remove the pump & inspect it for damage if the oil is full & the filters are clean. If you don't have a loader or the loader is working and you have a clean filter & plenty of oil- the next place to check is the linkage going to the valve. Be sure that a rod or pin has not fallen out and that the lever actually moves all the way to the valve. If all of this is ok then you might need to do some more in depth troubleshooting. You could have a bad three point control valve. Three Point Won't Stay Up- Leaks Down. Lift the three point all the way up and close the lock valve (usually located between your knees lust under the seat- see fig A). Shut off the tractor. If the three point still seeps down then you probably have a bad lift piston oring because, by closing the lock out valve, you have eliminated the valve & everything else in the system. If the three point stays up then you likely have a problem with the three point control valve.
   / JD 4555 3 point won' #3
1st thing to do is put L/D control knob by your right heel seating in the seat into "minimum". Do other hyd function operate correctly?
Yes, loader and remotes work fine. Linkage is ok. 3 point won't raise.
Yes, other functions work. I'll look at L/D control this weekend.
Thanks.
   / JD 4555 3 point won' #6
I just noticed your tractor has rockshaft position sensors(parts key #12 & 27) that could be the problem.
Thanks Jim. I have them both ordered and will be able to try them tomorrow.
I replaced both sensors and it still doesn't work. I wonder if it's the electro hydrolic controller or the valve, hydronic Orifice control asm?
   / JD 4555 3 point won' #9
I was afraid of that when you stated you ordered the sensors. Do sensors have voltage? I will suggest to get and read a JD 4555 service manual. Have you asked your local JD dealer service manager?
I'll talk to the dealer and see what they say. Thanks.
40ft Sea Container (A52384)
40ft Sea Container...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
54in Fork Attachment (A51691)
54in Fork...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
