JD 4520 Anomalies
   / JD 4520 Anomalies #1
Cheyenne
Cheyenne, WY
JD 4520, eHydro, MFWD
My 4520 (with 64 hours) is at the dealer for warranty repairs of (1. fuel guage inconsistent readings and (2. high-pitched squeal emanating from just forward of the engine firewall. This squeal occurs when the FEL bucket is loaded and driving/turning manuevers are performed. According to the dealer, Deere is aware of these anomalies and is working on a solution---one of which is to stuff foam around some hydraulic lines to mute the squeal. Seems like a Mickey Mouse fix to me, and is completely unacceptable. Hope I'm wrong about the dealer's explanation.
   / JD 4520 Anomalies #2
I don't know about the high pitched squeal but I doubt very seriously that you'll ever get the fuel gage problem fixed.
   / JD 4520 Anomalies #3
4720 here
Exact same thing
about 90 hrs on it
Fuel guage and odd squeal from same area it sounds like.
Although I havn't taken it for service, I actually just figured it was one of those vibrations that was well - just there.
I've heard lots of problems with fuel guages too so I havn't been really concerned about that either.
Although the fuel guage is really gettin on nerves since it goes to empty sometimes when still 1/2 full...
Dont let them tell you your'es is the only one doing it.
tom
   / JD 4520 Anomalies #4
My 4520 has the same squeal also ,and mine only has 5 hrs. Haven't used enough fuel to see if my gauge has the same problem.
Mike
   / JD 4520 Anomalies #5
did anyone get these problems resolved ?
I havn't picked mine back up, it is in for repairs for these two items.
They think they have it figured all out.
They put a new fuel sender... will just have to test and see how that goes.
The noise they decided was in the steering column, I think they put some foam padding in there to resovle that. Will just have to see if it works out.
I can not pick it up yet as they broke the fuel door in the process of fixing the other items and are waiting for a part for that.
Just wondered how it turned out for you other guys with the same problem.
tom
   / JD 4520 Anomalies #6
Tom,
I just bought a 4320 (it's not even delivered yet) and I noticed a slight power steering squeal while test driving it. Is that what you are referring too?
Thanks,
   / JD 4520 Anomalies
My JD dealer fixed the two problems on my 4520---fuel gauge sender and hydraulic squeal near the steering column. The squeal was fixed according to JD engineering, who recommended wrapping some of the hydraulic lines with foam padding. So far, so good. Haven't used the FEL since the repair (that was when the squeal manifested itself).
   / JD 4520 Anomalies #8
Sounds like what I was talking about....
It usually wasn't all that bad,,, but once in a while it was loud enough that I was actually afraid it could cause some hearing damage. I might have been over-reacting but I'm very particular about hearing. My hearing already seems to be suffering and I do all I can to protect it within reason.
They wrapped foam around something inside the column I believe.
The fuel guage they just replaced sender... Guess I'll get to test whether that works or not as it was intermittent anyhow - it may be a while before I"m sure. As soon as the weather gets above freezing most likely,,,,, brrrrrrrrrrrrr
tom
   / JD 4520 Anomalies #9
By the way congratulations on the new tractor ....
Hope you enjoy it as much as I enjoy mine......
tom
   / JD 4520 Anomalies #10
I'm supposed to meet the delivery people on my property about 8:00 A.M.. That would be fine if I could possibly get a good nights sleep plus it's 20 miles from my current house.
I guess it could be worse...I could be getting socks for Christmas!! /forums/images/graemlins/tongue.gif
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52748)
Kubota BX2680...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
