JD 4500 brakes not working....
   / JD 4500 brakes not working.... #1
StevenPaul
Anderson County, SC
John Deere 2010 (Kranky), JD 4500
Hello All!
Just a real quick question about brakes, my wife said that the brakes were working when she was last on the tractor. I get on it and notice that I have no brakes. It's a JD 4500 and I'm at a loss as to what could've happened. Could a low fluid level cause this?
thanks for any and all advice and help,
Steve
   / JD 4500 brakes not working.... #2
Check the linkage under your tractor. There should be a turnbuckle on each side underneath that might need tightening. There is also linkage inside the plastic panels underneath the console. U might have a loose nut or something in there. Hope this helps because i've been right were u are except my brake were doing the reverse(sticking).
ArkLaTexSam
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2010 International 4300 2,000 Gallon Water Truck (A49461)
2010 International...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
