Backhoe JD 448 Backhoe Issue
   / JD 448 Backhoe Issue #1
CrashedCT
Woodbury,Connecticut
2007 John Deere 3320
Has anyone had issue with the Center pivot on the 448BH? I have a 2007 3320 with 448BH and I noticed squeaking from the backhoe the other day when I was using it. After taking a closer look.. I found that I am unable to grease the center pivot zerk on the backhoe.. I removed the zerk fitting and made sure it wasn't clogged.. reinstalled it.. and am still unable to grease the pivot. Has anyone experienced this? Is it hard to dissassemble? I am not sure why, if grease flows thru the zerk, I would be unable to grease the pivot point? I am hesitant about using the backhoe with the center pivot dry. Can someone confirm the connection type? is it bearings or just a bushing?
any help would be appreciated.
   / JD 448 Backhoe Issue #2
Here is the likely reason: There is "pressure" on the pivot so the grease can not get into it. Use the hoe to take some weight off of the pivot and I will bet it will take grease. My front axle pivot is the same way, if I don't lift the front off the ground (usually with the loader) then I can't grease it.
fair enough.. thanks for the advice.. I will try that..
   / JD 448 Backhoe Issue #4
On my 447 I move it left and right as I put pressure on grease gun. This normally does the job. :thumbsup:
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2015 CATERPILLAR 279D SKID STEER (A51242)
2015 CATERPILLAR...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52128)
NEW Work Saver...
HOBBS MODEL-666 16' HAY RAKE (A51243)
HOBBS MODEL-666...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
