Rylynne Farms
- Joined
- Jul 6, 2011
- Messages
- 3
- Location
- Picton, ON, Canada
- Tractor
- Case IH 7110 magnum, JD 4450, Zetor 5340
I have tested the solenoid and it works fine. You can also hear the piston moving back and forth when power is applied. However when I removed the valve the "o" rings seemed to be fine but there were very fine metallic filings in the filter screens. I cleaned this up with air and reinstalled and still it will not disengage! Could there be a pressure problem or something more serious. The large gasket seal around the clutch housing is leaking as well if that indicates anything.
