Tiller JD 445 tiller pto speed?
   / JD 445 tiller pto speed? #1
Bowhunter
southwest Indiana
Kubota BX2200
My dad has a 455 garden tractor and a 445 rotary tiller (54" pto driven). I have a Kubota BX2200 and am hoping to find a pto adapter that will let me hook up the pto shaft to my tractor. My tractor has a regular male end on the tractor, while the tiller's pto shaft also has a male end.
My question is does anyone know the pto speed of this tiller? I know some cat. 0 equipment runs at 1000 rpm. My tractor runs at 540 rpm. I want to make sure I'm not wasting my time finding an adapter if the speeds don't match. Thanks.
   / JD 445 tiller pto speed? #2
Per the owners' manual, the 455 is equipped with a 2000 rpm mid PTO.
Ours doesn't have the rear PTO and there's no mention of it in the manual.
I believe rear pto and lift was available as an option only. I learned in the lawn/garden section that the rear pto is 540, so everything should work for me. Thanks.
   / JD 445 tiller pto speed? #4
I'm planning on adding a 42" bushhog to my 455 this year. The standard rear PTO is 540 female. The dealer sells a $65 male shaft to adapt it to a conventional PTO. Methinks your tiller male end is setup to connect into standard PTO config.
Hardi Navigator NP1100 Pull Type Sprayer (A49339)
Hardi Navigator...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A48082)
Year: 2016 Make...
2004 Ford E-250 Cargo Van (A46683)
2004 Ford E-250...
78in Bucket (A49251)
Field Cultivator (A49251)
Field Cultivator...
2022 Gulf Stream Kingsport 248BH Travel Trailer (A48082)
2022 Gulf Stream...
