JD 445 Flooding
   / JD 445 Flooding #1
Dustin0330
North,GA
John Deere 445
I recently bought a 445 from a friend who said it had a flooding issue and he assumed it was the injector. I pulled it into the shop today to do some diagnostics and found that the right cylinder only had 60lbs of compression due to the valves being way out of adjustment. The right cylinder was bone dry but the left was severely flooded. I adjusted the valves and now I have 200lbs of compression on each cylinder but I still have flooding issues. The fuel pump will properly prime the system but the injector will leak down into the throttle body. The previous owner was unaware of the problem with the valve clearance so he tried to disassemble the injector to see if it could be repaired. Im thinking the injector was damaged causing it to flood the engine but I would like to confirm that there's no problems with the fuel pressure regulator or any other sensor before buying a new injector. What would be the best way to check these parts?
2020 Kinze 3505 High Speed 6/11 Planter (A56438)
2020 Kinze 3505...
TANK MANIFOLD (A58214)
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
Gravely ZT 1540 Zero Turn Commercial Mower (A59228)
Gravely ZT 1540...
RoGator RG1100C (A56438)
RoGator RG1100C...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
