JD 445 Engine Oil Leaking
   / JD 445 Engine Oil Leaking #1
Gowfster
Tioga County, NY
JD445, Ferris is3200 x2, LS4047, JD 1600 WAM, Kubota RTV
My '94 445 has recently developed a slow leak of engine oil. At first the location seemed to be left valve cover (when seated) as the plug well had oil in it. I found that the torque on that side was indeed low and now I don't see any from that area, but the drips are still on the ground and seems to be from the front of the engine. Hours are low (400+) and it may soon go on to greener pastures as I'm upgrading to a Kubota BX23 to get the backhoe, but I want to make sure the 445 if perfect before I advertise it, and don't want it to sit at a dealer. My overall experience with this tractor has been incredible- 60" mower does a great job, even in heavy grass, and the 2 stage blower from JD is second to none in Heavy upstate NY snowstorms. Appreciate anyones past experience with small oil leak before I really dig in to it.
Tim
2008 ELGIN SWEEPER (A48992)
2008 ELGIN SWEEPER...
PUMP JACK (A48992)
PUMP JACK (A48992)
2014 Dodge Journey Value PKG (A46684)
2014 Dodge Journey...
2007 MACK CXN VISION (INOPERABLE) (A48992)
2007 MACK CXN...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2009 HINO 185 18FT BOX TRUCK (A45679)
2009 HINO 185 18FT...
