Rob_H
I have a JD445 that I was mowing some rough stuff with last week - wetlands that only get dry enough to mow about this time of year - so the grass was 3-4 feet tall, swamp iris, cat tails etc. I've done this many times before, and the 445 handles it well considering I should be using a rotary cutter.
The mower does bog down from time to time, and I stall it occasionally. Last week it had stalled three or four times in an hour's worth of work, and started just fine after each stall. The last time it stalled and wouldn't start - the fuel pump clicks, and the starter won't engage - just kind of whines.
I thought I had over-stressed the battery, so I put a full charge in it, but it still won't turn over. Any ideas?
Oh yeah - it's one of the last 445's made, produced in 2001 so it has a metal cam, also has the hydraulics and sub frame for a model 40 loader. 430 hours total, and this work is the toughest it ever sees.
Thanks!
Rob in MA
Thanks!
Rob in MA
