Alabama Brownneck
I have a 2000 JD 4400 that I recently purchased. Yesterday I used it to move some firewood and a few other mundane chores, which required me shutting down and starting up the tractor at least nine or ten times. After the work was down I shut it down and called it a night. Today I went to start it and nothing. I turn the key and the dash panel does not light up and I hear no click from the relay. Naturally I checked the battery which is fully charged,even still I removed it and had it tested at the local autozone ( tested good). So apparently I'm not getting power when the key is in the on position... must be a blown fuse for the ignition switch is what I thought....nope fuse is fine. Then it must be the start relay....nope start relay is fine. So now I'm stuck and don't know what to check next.
What would prevent the dash lights and relays from energizing when the key is turned to the on position?
