I think the thing to consider when buying something that is made in India, China, Russia, or any of the other places that are known for shoddy workmanship is to look at the company first and then the parts second.
Companies like JD, NH, Ford, GM, Volkswagen, G.E., Dell, etc all operate all over the globe. Each of those companies makes top flight goods. When they have a part made in a Russian factory, that part is spec'd to their company standards. Just because pretty much all bolts, bearings and metal casting for a transmissions may look the same does not mean they are the same. If the part is going into a name brand piece of equipment it is made to their standards.
Take JD & Yanmar or NH & Shiburu as great examples. Yanmar makes a fine tractor in its own right, as does Shiburu, but buying a Yanmar is NOT buying a Deere, nor is buying a Shiburu buying a NH. Sub-contractors all over the globe make components and the quality of those components is tightly controlled by the big companies such that they make sure only high quality parts go into their machines. Cut rate machines like Jinmas use cheaper parts than Deere uses, yet both build tractors in China. Jinmas are held to completely different, and much lower, standards. Doesn't mean they are bad machines, but it sure as heck means they are not Deeres!
Let's all understand that the country of origin is not the quality control agent, it is the company that specifies the part that actually controls the quality.
