JD 4320 Mods
   / JD 4320 Mods #1
idaho04
In short, I am selling my old Ford 1900 to my neighbor after I bought JD 4320 last year. I need info on the following:
1. I would like to attach my old Bradco backhoe, where do I get (or get info on) attachment brackets for the 4320?
2. I need a 'power beyond' connection for the backhoe and my splitter. Can I buy a kit from JD, or what parts do I need? Where to get info?
3. I have one extra valve and outlet on 4320. I could use one more for my box scraper. What do I need? A kit from JD? Where to get info?
   / JD 4320 Mods #2
For the backhoe, you should try to identify the model number and contact Bradco.
Deere hydraulic kits seem to be fairly reasonably priced, if you know exactly what you need and have good sources you can save a little but by and large the OEM kits are cleaner installations and cheaper that many DIY attempts. I would track down the nearest Deere dealer and ask for a Power Beyond kit and check out any extra SCV kits they may have. Installing it yourself vs. having the dealer install it is more based on your experience level and how much your time is worth to you - for the most part they're well documented and easy installations.
2009 Heartland Camper (A50514)
2009 Heartland...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2025 12V Diesel Pump and Hose (A50323)
2025 12V Diesel...
New Holland 824 2 Row Corn Head (A50774)
New Holland 824 2...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
