JD 4320 lower on hydr fluild ,how much to add
   / JD 4320 lower on hydr fluild ,how much to add #1
JYD
Bronze Member
HI All,
I have a JD 4320 with only 40 hours on it. I recently checked the Hydraulic fluild level and it was on the A on the ADD line on the dip stick.
So I am low on fluild. I have never noticed any leaks. so maybe it was low when I purchased it. This was the first time i checked it, I guess I should check it more often
I do not want to over fill it. Any idea how much I should add?
JYD
   / JD 4320 lower on hydr fluild ,how much to add #2
I can't answer the "how much" question, but make sure the 3PH and the FEL are all in the fully lowered position's when checking the fluid.
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
2017 JLG 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG 10054...
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
