JD 4320 Loader post
   / JD 4320 Loader post #1
Davo
mid CT
JD 4320
Hi all. I have a JD 4320 and over torqued one of the 4 bolts holding the post which the loader attaches to. It's an M16 bolt with course threads. I've looked for Heli-coil kits for this and they are in the $120-$140 range. I've never used a Heli-coil and don't want to spend the money and buy the wrong kit. My local parts stores don't carry any this big and I'd have to order over the internet and you know how hard it is to return things over the net if it's the wrong size. If I order a Heli-coil for an M16 bolt with course threads will that fit my M16 bolt? I'm sure you can understand my hesitation when dropping that kind of money on something I don't have a lot of experience with. Thanks for your help.
Davo
   / JD 4320 Loader post #2
The price really is steep.. Although it has been quite some time that I have purchased them.
The Kit probably has a drill bit and Tap that could be sourced stand alone. I would also recommend using Red Loctite on the Coil.
This will work very well if done correctly. Just dont break the Tap:eek:
If you have any machine shop tool suppliers in your area they should carry what you need.
The Kit will match whatever you speck. M16 course is just that and there is no variation. If your not sure of the thread or size take the Bolt to a hardware and find a Nut to match it
Thanks. I will buy the kit then. The tap itself goes for 80 bucks. It's a decent sized bolt. Everybody has them in the M12-14 range but noone has the M16 except the internet places.
Another question though: If it says a kit for M16x1.5 or M16 x2, what does the number after the x mean? I've looked on the web sites and even the Helicoil manufactuer site and couldn't find what that meant.
Thanks again
P.S. is this the kit you think i need?
HCMKC16
#5403-16 $ 115.33
THREAD REPAIR KIT: M16X2
5403-16
Weight: 2.50 lbs
   / JD 4320 Loader post #4
The second number is the thread pitch in mm. (course/fine)
   / JD 4320 Loader post #5
Davo, could ya use a longer bolt and nut combo ?
No I can't use a nut because it bolts into the engine block.
   / JD 4320 Loader post #7
For what you are spending on the kit and shipping, I would check with some locale repair shops and see what they would charge you to do it. If you screw up drilling the hole or tapping the threads you are in deep trouble. There are also different kinds of thread inserts. Since it is going in the engine block I wouldn't want to take a chance of screwing up.
Bill
Well Bill it's in the Lord's hands now. I kinda wanted it done this week seeing as I've been stewing on this for a few weeks. I got it for $115 and $10 3 day shipping. I really appreciate the responses and I'll let you know the outcome. The machine shop was a good idea though. I hadn't thought of that.
   / JD 4320 Loader post #9
You need to be VERY careful when you drill the hole prior to tapping it for the heli-coil. I put several 5/8 x 11 tpi heli coils in my 48 B tractor last year. The problem is holding the drill so that it does not jump around and make the actual hole larger than the drill bit. If that happens, the heli coil may not hold as well. If you can, I strongly suggest making some kind of jig so that you can drill perfectly straight and not have it wander. I wonder if you could make a plate, drill two holes, one to put a bolt in where you have good threads, and the other as a drill guide.
I bought my SAE large sized heli coils on EBAY. MSC also sells them.
Good luck!
Wayne
Hey Wayne thanks. I saved about $25 buying it from Northstate. Ebay didn't have any that size. Great idea about the jig.. I'll have to look for some plate around here and make one. You guys have all been great. Thanks for all your advice. If you can think of any other techniques please let me know.
Thanks again
Davo
Hydraulic Dock Lift (A47384)
Hydraulic Dock...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
40' CONTAINER (A51244)
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2010 Kubota L3400 (A50120)
2010 Kubota L3400...
