JD 4320 Hydraulic 3pt raises very slow and not to capacity
   / JD 4320 Hydraulic 3pt raises very slow and not to capacity #1
Rw43502
Archbold, OH
4320 John Deere
Just added hydraulic fluid and new filter but still will not lift over 750 lbs
   / JD 4320 Hydraulic 3pt raises very slow and not to capacity #2
How are the scv and steering? Do you have a gauge to check Hydraulic pressure? If you shut off engine with hitch in raised position, does it drop quickly or does it stay up? When hitch raises, is it smooth or jerky? Does oil temperature have any effect on operation?
   / JD 4320 Hydraulic 3pt raises very slow and not to capacity #3
Which 4320 116 pto hp rowcrop or 40 pto hp CUT?
   / JD 4320 Hydraulic 3pt raises very slow and not to capacity #4
Are you using JD HyGuard oil in the system?
I have heard that can make a difference. It maybe a myth, but that is what I have stayed with.
   / JD 4320 Hydraulic 3pt raises very slow and not to capacity #5
Which model 4320 tractor?????????? This one 4320 Compact Utility Tractor - 06Jun11 ( FR DE IT ES SV ) or this one 4320 Tractor - 16May11
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
John Deere 960 Culitivator (A50514)
John Deere 960...
Kubota GR2120 (A47384)
Year: 2004 (miles exempt on title) Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: (A51694)
Year: 2004 (miles...
