JD 4320 front axle seals
   / JD 4320 front axle seals #1
farmglide
Brookfield MA
JD 4320
The left front axle seal on my 4320 is seeping a bit and I would like to know if anyone has done this repair and if so was it much of a job?
I guess I should purchase a repair manual as the machine has 1500 Hrs on it and stuff happens.
Thanks for the response, FG
   / JD 4320 front axle seals #2
FG, not difficult at all. Remove the wheel, remove the cover plate #24 over a drainpan. Once off, remove snapring #16 and push the axle shaft out of the cover. Replace seal #22 and assemble back together. Top off with oil.
Good luck.
TT,
I should have been more specific.
Looks like 30 is the seal that is leaking.
Where did the exploded diagram you enclosed come from?
Thank you for your reply, FG
l
   / JD 4320 front axle seals #4
FG, I have not disassembled that portion and have not studied it enough to advise.
Here is the link on the JD site to the parts illustration: John Deere - Parts Catalog. Input your model number, select sectional index, powertrain, front spindle.
John Deere Van Brunt Grain Drill (A50515)
John Deere Van...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2013 Ford E350 Box Truck (A47384)
2013 Ford E350 Box...
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
