JD 4320 Cab Arrived
   / JD 4320 Cab Arrived #1
kromc5
2024 YT359c
We purchase from Jim at Quality Equipment in Roxboro NC, he was extremely helpful and is a no pressure salesmen. Very knowledgeable on all the tractors and implements. His pricing was inline with many other dealers.
Took me quite along time to purchase a tractor and no intention of buying a cab. Looked at all the tractors that were close to me, Kubota, Mahindra, TYM, New Holland. Went to my local JD dealer and looked at the 4105 with loader and 84 rear finish mower. We went back and they had a 4320 with cab we test drove that, my wife said she had to have the cab. I like the cab as well and really like the cruise control. We did add the air ride with I highly recommend. We did have to scrap the front loader to keep payments down but was not necessary for us at the moment. Currently the only need is moving large pine, oak and brush for cutting and burning. We have been very happy so far, the tractor will pull just about anything. Pulled large oak from the woods across my field while it plowed two nice ruts, did require 4 wheel drive with the diff lock to keep from spinning in a few areas, rear tires are not loaded. First day I had it it was 94 degrees had to actually dial the ac down to lowest setting as it cooled so well.
   / JD 4320 Cab Arrived #2
Nice machine. It won't be long - you'll be going back for that loader LOL!
   / JD 4320 Cab Arrived #3
Nice machine! Great pics!
I'm gonna echo om21braz...you'll be going back for the loader....less then a year, I'd wager.
   / JD 4320 Cab Arrived #4
Nice looking rig. You'll never regret getting the cab -- trust me. Best of luck with your new machine.
   / JD 4320 Cab Arrived #5
Good choice of tractors:thumbsup: Enjoy your new tractor:D
You will find that with some weight added the wheel slip will be reduced dramatically. I use six 70# front weights and three 110# rear wheel weights each side.
   / JD 4320 Cab Arrived #6
Steve,
How do you like the rear wheel weights? I think Deere makes two sizes 110# and 150# or something like that. I was wondering if you felt the 110's were good enough? They're expensive.
Rob
Kromc5- good luck with the 4320. My friend has a 4xxx series and we just pulled two 50 foot downed maples off the road after a storm.
   / JD 4320 Cab Arrived #7
Steve,
Rob
I think only the 110# weights are for the 4x20. I have 4 on the rear of my 4520 with R1 tires. If I added 3 to each side, the last one would protrude outside the rim an I did not want that. Maybe different with R4 tires.
If you could get 150#s, then I would go with 2 of the bigger ones on each side.
   / JD 4320 Cab Arrived #8
Steve,
Rob
The 110# rear weights are the only ones I am aware of being available for this tractor. No problems with the weights and I use a heavy boxblade and landplane/grader which is a good test. Weights are expensive but so is replacing and handling Rimguard or other products over the life of the tractor.
   / JD 4320 Cab Arrived #9
I'm green with envy. If only my shed door was 1 foot higher ... dreaming
   / JD 4320 Cab Arrived #10
I agree whole heartedly. I have to call my dealer and ask him what weights the 3x20 series take.
Rob
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
Cat DPL40 Forklift (NOT RUNNING) (A50774)
Cat DPL40 Forklift...
2015 Freightliner M2 106 26FT Box Truck (A50323)
2015 Freightliner...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2014 Nissan NV200 Cargo Van (A50323)
2014 Nissan NV200...
