JD 4310
   / JD 4310 #1
JMS_NJ
Recent post about 3-point hitch turn buckle breaking has me wondering. If the lift arm axle housing is made of aluminum, should there be a concern that it's not strong enough. Over time will it fail? My concern as a potential 4310 purchaser is that aluminum has no place at such a vital area. Need help as to whether I am concerned for no good reason.
   / JD 4310 #2
Re: JD 4310 reliability.
You don't hear much more than this one thread about what is one of the most popular models in the very popular 4000TEN line.
As I read that thread, it seems that the poster had three problems with his dealer for any one apparant problem with the equipment. His dealer should have had whatever was causing this issue fixed long before there was an issue.
I wll try and find out the construction of that part. I am willing to bet a magnet sticks to it when I try, later.
   / JD 4310 #3
As someone looking to purchase a 4310, I am in the same position you are. So... here goes my 2 cents.
Just bacause one user has had problems, I don't feel that the 4310 is necessarly a bad machine. I do, however, feel that it is important to make sure that the machine is used properly, that all 3-pt attachments are properly sized and installed correctly.
As it has been stated earlier, every machine has it's limitations and it is important to realize them before purchase. Considering that I plan on using a 5ft brush hog and a rear finish mower, (as well as some moving of dirt, gravel and hay with the FEL) I feel that the 4310 is sufficient to accomplish everything I throw at it.
(Anyone from Club 4310 feel free to correct me as you already have your machines /forums/images/graemlins/grin.gif and I don't... /forums/images/graemlins/frown.gif).
2016 Ford F-150 Pickup Truck (A49461)
2016 Ford F-150...
2006 International 4400 LP Ambulance (A50323)
2006 International...
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
