JD 4300 with 420 loader removal mechanism missing
   / JD 4300 with 420 loader removal mechanism missing #1
swampbuggy77
Oviedo, FL
John Deere 4300
I recently purchased my first tractor, a JD 4300. I has the 420 loader on it, but the mechanism that allows the loader to be parked was all removed (handle, rod, spring, etc). The front frame (that connects to the push-rod), which is ultimately the parking stand, has two bolts through it permanently attaching it to the front of the tractor.
Is there a way to find the parts to make the loader removable again (handle, pushrod, etc...)? Looking in the JD Parts Catalog, I believe this assembly for the 420 loader is called the MAST AND LATCH CONTROL ROD - ST406418? Am I heading down the right path?
Below is the parts list. Any suggestions on where to find the necessary parts?
6-Pivot W43514
7-Handle W43516
8 - Grip W33150
9 - Cap Screw 19M7166 (M10 x 20)
10 - Rod W44541
18 - Leaf Spring W43529
11 - Bolt 03M7192 (M10 x 30)
12 - Nut 14M7152 (M10)
13 - Lock Nut 14M7517 (M10)
Thanks in advance!
2015 Hooper T/A Trailer w/Mounted Foaming System (A50860)
2015 Hooper T/A...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
BBQ Pit (A50860)
BBQ Pit (A50860)
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2025 KG44 UNUSED Double-Ply Polyester Slings (A50860)
2025 KG44 UNUSED...
