JD 4300 transmission choice
   / JD 4300 transmission choice #1
Anonymous Poster
Epic Contributor
Trying to decide if I should spend the extra money for the hydrostatic transmission vs std.
   / JD 4300 transmission choice #2
Go hydro!! There are 4 things that must be on any tractor that I would buy, 4WD, powersteering, FEL and hydro! ....Did I mention get the hydro? It is worth it in resale alone. Once you own a tractor with it you will wonder how you got along without before!.. Go hydro.. oh, i said that already.
   / JD 4300 transmission choice #3
Greg,
What are you going to be using your tractor for?
   / JD 4300 transmission choice #4
I have 4300 with hydro and I'm happy with it.
Chuck in IN
I live on 22 acres and will be using the tractor for blowing snow, bring in firewood, cutting grass and other odd jobs. As you see it will be used a lot. Most people are telling me to by the hydro trans. The cost is a lot more and I not sure if it is worth it. My current tractor is a Alis CA (1953) with a woods mower. As you can see I am use to a std.
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
1262 (A50490)
1262 (A50490)
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
