Good evening, I have a JD 4300 that has a hydraulic problem. I used the tractor all day today to shred and, late this afternoon, the steering started getting "tight," and the bucket wouldn't go up after going down. I was about 400 yards from my shop so I drove it there and parked it for a while. When I came back to start looking at it, I noticed hydraulic fluid leaking apparently behind the hydraulic pump. There were several hose clamps that connect the suction lines to the pump, so I tightened each of these (they all benefitted from tightening them), but the leak is still there.
Here's how the tractor's hydraulics are functioning:
1) low engine speed = no power steering, no bucket lift or curl
2) high engine speed = good power steering, slow bucket lift and curl, but unable to pick up much weight.
Right before I stopped for the evening, I looked at the hydraulic section of the factory workshop manual but haven't studied it closely yet.
Apparently the pump is a tandem pump, with the front pressure for the power steering and HST and the back pressure for everything else.
I have some ideas about what is wrong, but I don't want those to influence any on-line diagnoses from others. One thing that I will add is that I am guessing that my use of the extra SCV ports on the factory SCV to install two connections for my post driver at the rear (or log splitter, etc.) may be related. I am thinking that I may have hit the actuating lever for these extra SCV posts and they got locked in one direction for at least a period of time under load and I didn't realize it because of the intensity of the work and the noise. Note that this is merely a guess and is not based on finding the lever locked in one direction or the other.
Any help would be appreciated!
Richard Easley
Waco, Texas
Richard Easley
Waco, Texas
