Hello All,
I have learned a ton reading all the info here having bought my first tractor, a JD 4300 Hydro...360hrs. The tractor will run from idle to rated rpm but as soon as I touch either the FWD or REV peddle, the engine rpms drop to 0. If I let off the peddle prior to stall, it will recover, if not, it stalls. I have sumped the fuel tank at the fitting and also changed the fuel filter, because I had the tractor acting up before I realized there was a fitting there to sump the fuel tank. Do you think my carberator is clogged. Thanks for your help in advance, this website and the people on it seem to be very helpful.
Chris
Chris
