JD 4300 ball joints (tie rod ends)
   / JD 4300 ball joints (tie rod ends) #1
pat32rf
Veteran Member
Bancroft, Ontario
JD4300
I recently noticed a fair bit of play in my left tie rod end so looked up the pt # on the web and called the dealer. He confirmed the pt # and got it on order. When I went to install it I found that the threaded portion was slightly undersized. Further checking showed that it should be a 1" thread, but the replacement was metric.
Turns out that the number in the book was wrong, but the tie rod end from a 4320 was a perfect fit...
Anyone else run into this?
   / JD 4300 ball joints (tie rod ends) #2
will post if I run into the same problem I am looking for tie rod ends and just realized they may call them ball joints insted of tie rods so thanks for the information
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2013 VOLVO VNM DAY CAB (A51222)
2013 VOLVO VNM DAY...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
JCB 5 10 56 (A50490)
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
