Max lift at the pivot pin: 101.4 in.
Kubota is 102.4"
Max dump angle, at ground/full height: 130/45 degrees. Kubota is 40 degrees
Max rollback angle, at ground/full height: 30/64 degrees. Kubota is 45 degrees
Lift capacity to full height, at the pivot pin/front bucket edge (550mm from the pivot pin) : 1,258/1,045 lb.
Kubota is 1870lbs and 1400lbs.
Lift capacity to 59 in. (1.5 meters), at the pivot pin/front bucket edge (550mm from the pivot pin) : 1,943/1,687 lb.
Breakout force, at pivot/bucket edge (550mm from the pivot pin): 3,299 / 2,417 lb-ft.
Kubota is 2605 @ 500mm forward of pivot
Rollback force at the bucket edge (550mm from the pivot pin), at ground/59 in./full height: 2,988/3,349/2,155 lb-ft.
Those are the primary numbers to concern yourself with. I'm not sure what is relevent about 59" lift heights, but JD does give more information. As was mentioned, give them a drive. Look at the build quality, Kubota loaders are built in Georgia and JD's in Canada. Look at the way they attach. I put a gauge on my loader control valve and at about 1400 RPM have maximium operating pressure or about 2700 PSI. At that point your pretty much going to be able to do what the loader can do. The cyle times on the LA 723 are very quick, something I really like. /forums/images/graemlins/wink.gif
