JD 430 S Hyd Pump Removal/Repair
   / JD 430 S Hyd Pump Removal/Repair #1
steveb103
Johnston County NC
1959 JD 430 S, 1958 430 W, 1988 Ford 4610 SU
My 430 S hydraulics worked good for about 20 minutes and just quit working. Discovered that the crankcase level was increasing - obviously because of hydraulic fluid. At least that's what I think. Ordered the seals and gaskets necessary to reseal the pump. Anyone out there have experience with hyd pump repair that could offer advise? Thanks a lot! Steve
   / JD 430 S Hyd Pump Removal/Repair #2
I went to JD parts book page on the 430, and found the pump. Looks similar to the one on the MT I had, only the MT had two halves, not a center section like your 430's.
They're pretty simple to work on. Hardest part will probably be getting the snap ring off the driven shaft, plus the small woodruff key. You'll need to get them off, so as to remove the pump shaft, and remove the old & install the new seal, etc.
I replaced two of the woodruff keys in my MT's pump. One was the, already sheared one in it when I bought the tractor. Apparently someone had jacked up the pressure relief, and I sheared the new one, before I figured out what the problem was.
And you have to keep an eye on the o-rings when you put the sections back together. Watch they don't pop out of the groove, and pinch them, or you'll be buying more.
For some reason, I'm thinking the original body o-ring was square shouldered, but the new had been superseded with a round one. Could be I'm thinking of something else too, as I've had several different one's apart.
And be sure to keep everything clean..!!
Thanks for the info. I probably will scavenge the pump from the W to get the S going. W needs a lot of work, so rebuilding the pump is just another task. Gotta work on the drive-way if the snow will ever melt and let the ground dry. Again, many thanks!
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2019 John Deere S780 Combine (A53342)
2019 John Deere...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
UNUSED FUTURE ECA63 ARTICULATED BRUSH CUTTER (A51248)
UNUSED FUTURE...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
