JD 430 metal hydraulic line
   / JD 430 metal hydraulic line #1
sos1
Bronze Member
One of the metal hydraulic lines at the rear of my 430 needs a new connector that screws onto the quick coupler. The old one appears to have some sort of sleeve that slides over the metal line and fits inside the connector. Is this sort some sort of compression fitting or what?
   / JD 430 metal hydraulic line #2
Can you take a picture? Most of the steel lines have brazed fittings on them, not compression.
I'll get one out tomorrow. The sleeve appears to have a flare on one end. Slides on the tube and the connector which is already on the tube slips over the sleeve and screws onto the fitting.
   / JD 430 metal hydraulic line #4
Steel tubing with a flare on the end is usually a JIC 37° flare connection. It's a very common connection in hydraulics.
JIC 37° Hydraulic Tube Fittings > Discount Hydraulic Hose.com
There are some other flared connections (SAE 45° flare and SAE Inverted Flare), but they are not used as much in hydraulics. If you can post some photographs, that will definitely help.
New/Unused AGT MX-CRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
INOP/NON-RUNNING 2005 Toyota Prius Passenger Car, VIN # JTDKB20U253038319 (A51572)
INOP/NON-RUNNING...
1995 Rinker Captiva 190 (A53472)
1995 Rinker...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
