I am new to the forum and hope that someone can help. I have a 1986 or so John Deere 430. I just bought a 54" plow which seems to work great the questions I have are the following.
1) The plow only lifts up about 3 inches off the ground but when I push the plow down I can get the front tires about 6-8 inches off the ground. I switch the connectors thinking I had it backward but no luck. Did I do something wrong? Suggestions?
2) The hydraulic level closest to the hood seems to have a lock when you push it forward to hold the plow in the down position with pressure. Is this normal and how should I use it? I don't want to break the hydraulic system and have never used it before.
3) One other thing worth noting is that I contacted JD before I bought this used plow and could not get the two top pins on each side to fit correctly. I ended up having to grind the hole about a half an inch bigger.
Any thoughts?
Any thoughts?
