Price Check JD 425 Price Check
   / JD 425 Price Check #1
Sel
WI
Mid 90's Craftsman
Got my eye on two JD 425's, but what should I expect to pay? One with 322 hours and 54" deck, the other ???.
I plan on using this unit for dragging a spring tooth in a horse pasture, probably scraping the manure off a small winter pen, cutting up to 2 acres regularly and if possible, maybe some light end loader work for my manure pile (once a year maybe). Oh and plow snow. I assume this unit should be able to tackle all of these tasks with ease?
A subcompact is outta the question, and I'd like to stick around this mid 3 range I'm finding on used units.
Thanks.
   / JD 425 Price Check #2
Sel,
The 425's are good units. Some of the early ones had problems with plastic cams, usually around the 6-700 hour mark (the replacement is metal). They are very maneuverable tractors, the hydraulics are a bit slow (a loader would be a bit of a stretch, and also, very expensive -- not to mention needing every bit of weight you can get on the tractor). Maintenance and history are going to be everything. I used mine for ~ 10 years and 700+ trouble free hours.
I'd be looking to use the loader or blade for scraping manure, not so much for lifting and carrying other than moving a little manure now and then, or pushing snow/dirt with a blade.
It comes down to whether or not I'm better off purchasing a 4 wheeler and some attachments for heavier work and a lawn tractor or 0 turn, or get a garden tractor and kill two birds with one stone. I'm under the impression that the 425 could handle my 2 acre lawn and are small pasture work fine.
Yes a sub compact would be nice, but so would an extra 10G's in my pocket, neither are gonna happen any time soon.
   / JD 425 Price Check #4
Then with the plow (would handle the snow too) you would have a nice little package. I'd say, you could get a good deal in this price range. Just pay attention to service and usage history. /forums/images/graemlins/tongue.gif
   / JD 425 Price Check #5
The loader is the model 40, and it has a reputation as a bit of a lightweight and is pretty expensive, even used. I think the rated lift is around 300 pounds.
You might want to do some research at Weekend Freedom Machines . There are some great pages on the older JD's (before the 4x5 series) and a forum that includes a section for us late model (4x5 and newer) owners. There's a thread in the late model forums not too far back where one of the guys put bigger cylinders on his 40 and more than double its lift -- but at the expense of speed.
You might want to watch for a 455 instead of the 425. The extra torque from that little Yanmar diesel is awesome. You'll pay a little more, but still not what a SCUT would cost. With the work you have outlined, I would want the diesel. An older 430 might be worth a look, too, but the 4x5 series added power steering and foot controls for the hydro drive.
Honda EM5000s 5,000 Watt Portable Generator (A50325)
Honda EM5000s...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2008 Volvo XC90 Multipurpose Vehicle (A51694)
2008 Volvo XC90...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
