JD 425 gauges not working
   / JD 425 gauges not working #1
xer
john deere 4720, john deere mower 425, mahindra 8560
I have a JD 425 mower with 450 hours. I bought it new in 1997 and has been a great mower. Last week when I went to mown the yard, I noticed that the gauges were not working. I usually blow it off and wash it off everytime I use it. Can anyone give me some ideas what to check? I checked the in line fuse and it was good. The mower switch still works also, just would like to have a temp and gas gauge working properly.
   / JD 425 gauges not working #2
:welcome:
Looks like either the dash panel module or the fuel sensor or the temp sensor. Being it is both senders, I'd suspect the dash panel module.
There is a test procedure to isolate these three possibilities in the tech manual. I gather the s/n is under the 70000 when some changes were made to the 425.
thanks, I looked on ebay for tech manuals and found some CDs. Any recomendation on which are good? Is there a vendor on this site thay sell them?
   / JD 425 gauges not working #4
There is only one tech manual. It will be for the 425, 445, and 455 by Deere. Can get it at the Deere dealer as well.
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
UNUSED LANDHONOR LHR-SP50 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
