jb221
Hi guys, I have a JD 4200 with a 420 loader that we purchased a couple of months ago. We noticed the cylinder for the tilt on one side of the loader was bent and figured it would eventually become an issue. From the picture you can see that the other day the rod broke and now I need to come up with a fix. The local JD supplier is charging ~$500 to repair by putting a new rod on and rebuilding, and $560 for a new replacement.
Has anyone tried using a non OEM replacement on a 420 loader (or a 410 or 430 loader as I believe the cylinders are identical)? Would I need to replace both tilt cylinders if I went that route. Is the best bet just to pay the $560 and get the replacement?
Any help would be appreciated thanks!
