JD 420
   / JD 420 #1
bacajr420JD
Lena Wi
john deere 420
Hi everyone! New to the board! I have two JD 420's. One, I've had for several years and had been working just fine until about two months ago. Now when I turn the key all i get is a click. i've changed out battery and still just a click. I have another 420 that has a similar problem. Replaced starter, ignitiion switch, and battery and still just gets a click when I turn the key. I installed an ignition switch from my 300 and it fires right up. It seems I got the wrong switch. What problems could I encounter if I put an ignition switch from the 300 onto my 420?
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
Cat 60" Wheel Loader pallet Forks (A49461)
Cat 60" Wheel...
