JD 4110 with 410 loader
   / JD 4110 with 410 loader #1
4runner
Bronze Member
WNY
JD 322, JD 4110
How does the 410 loader on the 4110 compare in lift capacity and cycle time to a 200cx on a 2320 or 2520?
   / JD 4110 with 410 loader #2
I would say it equals the 2520 because it has duel pumps that are rated the same...
   / JD 4110 with 410 loader #3
The weight of the machine and horsepower has a bit to do with loader performance as well. When digging, or even just scooping from a loose pile of dirt, the machine's (ballasted) weight determines your maximum traction for pushing into the pile. The weight on these smaller machines also tends to set the upper limit on lifting capacity (before they tip), and finally, the front axel and tire ratings are something to consider. The slightly larger machine might have higher ratings on these.
- Rick
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2012 Ford F-250 XL 4WD Flatbed Pickup Truck (A50860)
2012 Ford F-250 XL...
2015 Jeep Patriot SUV (A48082)
2015 Jeep Patriot...
