Started the tractor today and was letting it run to warm up. I got back on the seat and as soon as I sat down the machine shut down, black smoke came from the engine compartment and it smelled electrical.
Background: About a year ago I was having problems with some acsessory work lights I jiggled the wire while the machine was running and same thing happened. Engine shut down, electrical smoke...wouldn't start.
That time, I bought a manual, educated myself and traced the problem to the starting solenoid and a blown fuse. I replaced both and the tractor has been running since then, but has been fickle about starting, I have to play with all the safety switches. Shift in and out of neutral, lights on the off etc, and eventually it starts. All this seems to be worse when it is cold, and it is cold today.
The starter solenoid looks like the problem again, There is black goop from the solenoid on the wire that go into it.
Should I replace the solenoid and the A1 controller this time? Could there be a short somewhere else that is the real problem? How would I figure this out?
