JD 4110 Replacement Seat
   / JD 4110 Replacement Seat #1
millsnhills
Bahama, NC
Been a while since I have posted, tractor is at 650 hours and I need a new seat. I went by the dealer today and they want 370+ for a new seat. Has anybody else replaced theirs or tried any on Ebay?
Jeff
   / JD 4110 Replacement Seat #3
I bought one off ebay for my 955. I went with the high-back without arm rest. When I got the seat, it turns out that it was a Milsco XB-200 seat. Milsco was the manufacturer of the original equipment seat on my 955... and it's made in the USA.
Thanks guys, went by TSC yesterday and they had one Yellow on for 139.00 it did not look like mine and did not specify which models it would fit. The deal breaker was it did not include any hardware either so I left. Thanks for the Ebay link because that was the exact seat and all I should have to do is pull a pin and slip in. THANKS
J
   / JD 4110 Replacement Seat #6
J
It would be a cold day before I would buy the replacement seat for two hundred dollars. Two inches of foam and a plastic cover that will crack in two years does not equate value. A blanket over your present seat would provide more cushion and you gained nothing but a brighter shade of yellow.
If you spend alot of time on the 4110 i would buy a suspension seat.
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
1973 POWER 30ft Pole S/A Towable Trailer (A48081)
1973 POWER 30ft...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
Unused Delta Crash...
Pallet of Propane Burners (A50860)
Pallet of Propane...
