JD 4110 fuel solenoid
   / JD 4110 fuel solenoid #1
adamh
tribes hill n,y
JD 4110 hst
I have an 04 4110 and the fuel shut off solenoid went bad and blew the 40a fuse. i replaced the fuse and plugged in the new solenoid without bolting it in to make sure it was going to work. when the key is turned it pulls in like it should but after a minute or two the thing is so hot you can hardly touch it. Is this normal??? I would really hate to burn out another one.
   / JD 4110 fuel solenoid #2
How many wires are going to it. some solenoids have 2 windings a pull and a hold pull ckt draws more amps but is only to energize it then hold takes over does it ground thru body or does it have ground wire.:)
Hi sorry for the delayed response it has 3 wires going to it red white and black. Is there a relay that changes it from pull voltage to hold ?
   / JD 4110 fuel solenoid #4
I'm not sure on this model some of them use crank to energize and run to hold it in. You can test this with a test light.
This is without the tractor even running this is with the key just in the run position. Maybe this model needs to be running before it goes to hold...I'll give that a try.
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
