JD 4110 engine stopped
   / JD 4110 engine stopped #1
Paul in Alabama
Hello,
I hope I can get some assistance with my JD 4110. This is a 3 year old machine with 100 hrs. During operations the engine shut down. I suspect an electrical component however I don稚 have access to an electrical schematic. After the engine stopped I attempted a re-start. With the key in the start position the starter won稚 engage (no power to solenoid). I have electrical power to the instrument panel and all lights work. Positive and negative battery and frame connections are good. Under the hood on the right-hand upper rear sided of engine compartment there is a black relay that clicks when the ignition switch is engaged. All four fuses are good. I would appreciate any input on what components and their locations that may be restricting current flow to my starter solenoid.
   / JD 4110 engine stopped #2
Safety seat switch... Maybe a bad battery (They can read good but not be good). I think it is your seat switch...
   / JD 4110 engine stopped #3
pto switch.. or other safety switches like neutral -safe.. should be checked.. and as the other poster said.. check volts on the battery while trying to start..
soundguy
   / JD 4110 engine stopped #4
That should be the fuel valve solenoid opening.
Safety switches?? :D
   / JD 4110 engine stopped #5
Things to check...
-Verify battery voltage while trying to start it.
There are 3 safety's:
-Seat switch (try pulling the switch UP when the seat is lifted, this positoin is for of-seat rear PTO operation)
-PTO switch
-Neutral switch (jiggle the lever while attempting to start)
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2021 Redirective Crash Cushion Guardrail (A48081)
2021 Redirective...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2021 Kubota SVL97-2HC Compact Track Loader (A50657)
2021 Kubota...
