JD 410C Steering issue
   / JD 410C Steering issue #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Neighbor has a 410C with MFWD and the steering is very erractic.
Symptoms are:
Steering wheel turns freely but the wheels do not turn. This happens steering in both directions. This becomes more prevalant as the oil gets hotter. I do not have a schematic or service manual to see what and or where there are test points.
Are there pressure test points on this machine? If so where are they.
On this machine if the priority valve is sticking would the steering wheel turn freely or be very hard to turn? I am thinking hard since it does not turn easily with the engine off.
Is there some form of anti-cavitation checks in the steering unit that would allow the oil to by-pass the steering cylinder?
When the system works it will turn even with a full bucket.
All other functions operate correctly.
TIA
Roy
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
*Selling at Royal Auction Zephyrhills, FL Location* 5 (A59228)
*Selling at Royal...
13042tx (A55973)
13042tx (A55973)
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
Killbros 260 Seed Conveyor (A56438)
Killbros 260 Seed...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
