Price Check JD 4100 Price Check Please
   / JD 4100 Price Check Please #1
Anonymous Poster
Epic Contributor
Greetings everyone! I am in the process of shopping for a used JD 4100 to replace my current JD 316. The 316 is a great tractor but just not big enough for my needs. I finish mow about 3 acres and remove snow from a 50' gravel driveway. While it handles the mowing fine, especially with a Swisher 44" trail-mower, the snow removal is a problem. I've priced a couple 4100s locally and was hoping someone could give me an idea of whether the prices are too high. The specs follow:
1. 2001, hst, 4wd, 95 hrs, 410 fel, 60"mmm $15,400
2. 2000, hst, 4wd, 180 hrs, 410 fel $12,500
   / JD 4100 Price Check Please #2
I just bought a new 4110 Hydro, 4x4, 410 FEL, Woods RB60 rear blade, JD 54" front blade and Imatch for around 16K from a dealer in PA.
   / JD 4100 Price Check Please #3
I paid about 14K before tax for a 4010 w/ 60" MMM, FEL, Imatch, and ballast box. I really wanted a 4110 but it was just out of my price range. Those prices sound pretty fair. With that many hours they are both about new. I probably would have bought a used one if there wasn't so many incentives at the time.
Good Luck!
   / JD 4100 Price Check Please #4
The prices on both tractors sound very reasonable. The low usage hours make both of them pretty much new. I'd buy based on weather or not you need to mow with your tractor. If you buy a mower for the lower priced unit, your total cost will be right in the ballpark of the higher priced unit.
Thank you very much for your input. I am close to making a decision on one of these machines. I'll let you know how I make out!
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
