JD 4100 and iMatch......
   / JD 4100 and iMatch...... #1
garchib
southern NH
JD 4100 HST, Craftsman YS4500
I have a 2001 JD 4100 HST and I am getting tired of removing my
ballast box and attaching my RMM and then removing the RMM, etc. etc.
Is the iMatch system compatible with the JD 4100 ? Do any
4100 owners use it ? How much does the hit cost ?
Thanks to all, G
   / JD 4100 and iMatch...... #2
I have a 2210 with the imatch. I believe it is compatable with the entire 4010 series. I love it. It makes life sooo much easier and saves lots of time. Retail is around $220 and worth every penny. The Tractor supply co has their brand around $180. Dave
Thanks for the info Dave, but I am "pre-4000 ten series", so my
original question still stands.......thanks for the pricing info though
   / JD 4100 and iMatch...... #4
garchib,
Doc meant to say the 4000 series....its compatible with the 4100...I dont have the Imatch yet, but I was told by my dealer its available. The 4110 has the same spec's as the older 4100 series (i.e the foldable ROPS from the 4110 fits the 4100)...its the implements that may or may not be compatible, depending on age..
Ducati996
The reason I asked is the 3pt hitch on the 4110 is MUCH more beefy
than on the 4100, so I didn't know if that was to handle the iMatch
system, or there was some freakish warranty issue.
   / JD 4100 and iMatch...... #6
garchib,
Not to disagree but they are the same. I have seen many 4110's and had mine 4100 next to a new 4110 (dealers lot)
Its the same 3 Pt setup....
Of course If I'm wrong on this I would appoligize...but I looked these machines over fully. That would have been an obvious change...
   / JD 4100 and iMatch...... #7
You might have the machine model number mixed up...
the 2210 has a smaller 3 Pt hitch limted cat 1, same as the 4050...just guessing
Duc
I had a 3PT hitch part bend on my 4100 and we took it out to look
at several 4110(s) and the lift links are MUCH larger on the 4110.
They are not the same part number. The dealer does not know why
they are bigger on the 4110 than the 4100.
Here is an example.....the part I had that bent was JD part #
AM879522, which is a liftlink part for a 4100. That very same "piece"
of the lift link apparatus on the 4110 is JD part # LVA801237.
   / JD 4100 and iMatch...... #9
I think the 4100 is still a limited category 1 just like the 2210. Either way if it works on a little 2210 I cant imagine it would not work on your machine but certainly your dealer could give you the final word on that. The iMatch unit is the same for all models. Dave
   / JD 4100 and iMatch...... #10
Hi Doc,
The 4100 is a full & true cat 1...its got plenty of clearance
and its the same machine as the 4110...I was at the dealer today and again saw a 4110....same **** thing....
Not sure what the confusion is but I can send a picture if any body likes....
Ducati996 /forums/images/graemlins/grin.gif
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2025 CATERPILLAR 265 SKID STEER (A51242)
2025 CATERPILLAR...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
Champion C80 B (A50322)
Champion C80 B...
