JD 410 high/low/park shifter question.
   / JD 410 high/low/park shifter question. #1
js127227
Park Falls, WI
John Deere 410
I am having a problem with the high/low/park shifter lever. The backhoe wants to move when the shifter is in the neutral position. When you shift it into low the backhoe just bogs down. I also noticed you can pull the lever all the way back towards you on the low side which I don't think you should be able to do. I took the top cover off of the transmission so I can see the shifter forks. Everything seems to be working properly. The set screw for the high/park shifter was loose so I did tighten that up. I tried to see if the shaft would move for adjustment but it did not so I just tightened it down. Everything else looks intact. The shifter lever is not broke at all. The forks that the lever go to are aligned also. I must be over looking something simple. I parked it one day after using it for several hours and the next day it won't move. Any help would be greatly appreciated!!
   / JD 410 high/low/park shifter question. #2
Sounds as if when you put gear shift lever in low you are in high range also.
2004 Ford F-250 4x4 Crew Cab Mechanics Truck (A49461)
2004 Ford F-250...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2014 Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
2014 Lay-Mor...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2011 WESTERN STAR 4900 SB (A50854)
2011 WESTERN STAR...
