greenmojo
- Joined
- Jun 19, 2012
- Messages
- 297
- Location
- Badger Mountain, WA
- Tractor
- John Deere 4300, John Deere 450C
Merry Christmas!
Quick background with as many details as I can provide.
I have a JD 4024 model 30kw generator that we use with our off-grid home.
Everything was good, I took a fuel tank to town for diesel and filled it with 250 gallons, brought it home and only put about 25 gallons in the generators base fuel tank before getting distracted, moving on and going inside.
Around midnight, I heard the generator struggling, almost like it was running out of fuel. Idling up, then down and fighting, then finally shutting down.
I verified there is plenty of fuel in the tank, manually cranked it over and started it, but as soon as the load picked up, it struggled and died. After some trying and quite a bit of cranking, I got it to idle again, but shorty after a minute or two, it died.
I believed it was a fuel issue, possibly a filter dirty or maybe water in the fuel. This morning replaced the filter, primed the filter with new diesel and it still wouldnt fire. It turns over, it just wont go. I even drained the bottom 5 gallons out of the tank incase it was water / contaminated.
I called Pape machinery, they sent a tech up, and he discovered the the fuel transfer pump had failed and he believed that to be the issue. I ordered one, but in the mean time he said I could use a universal fuel transfer pump to provide fuel until tomorrow. He recommended a 10 to 15 psi pump, however all I could find in town was a 9 psi pump.
I installed the 9 psi pump, verified that diesel was making it into the filter, bled and primed everything, and it still wont start. Just turns over, but no go.
Last thing I tried this evening was to pump the priming handle while it was cranking and for a few seconds it seemed like it wanted to to, it sped up, sounded like a couple of cylinders were doing something, but it just wont start.
I pick up the new correct fuel pump in several hours, but Im doubting it will fix the problem, since the universal one didnt have any effect. Any thoughts?
Does that 9 psi pump just not have enough pressure for the engine to start?!
I have no idea where to look next. Ive accidentally run it out of diesel before, and all it took was a little priming and a minute of cranking and it was back alive. Just stumped.
Thank you for reading!
