Loader JD 401A diesel loader looses rpm after about 3 hours runtime
   / JD 401A diesel loader looses rpm after about 3 hours runtime #1
zpq1045
John Deere 401A Loader
Hi All,
I have a JD 401A diesel loader that looses rpm after about 3 hours runtime. Outside temp doesn't seem to matter, 30 to 70f. Since the first time this happened I have replaced the fuel filter and fuel shutoff solenoid in the injector pump. Yes the solenoid was bad as a coincidence I guess.
Last time I didn't think that it would make it to it's parking space. Running about 1000 rpm at full throttel.
Any ideas?
Thanks.
   / JD 401A diesel loader looses rpm after about 3 hours runtime #2
Check flow from tank as dirt/grass or other unknown foreign material has been known to get in fuel tank. Also disconnect fuel return line on inj pump leading to injectors & tank. Then check while running to see if fuel comes out of pump fitting. If no fuel comes out remove fitting and try running engine again. This fitting has be known to get plugged with inj governor ring material.
   / JD 401A diesel loader looses rpm after about 3 hours runtime #3
Is it blowing any smoke? It could be a air intake restriction, so check your air filter. Make sure you are not collapsing your air intake hose between your filter and manifold. This could also be something washing over the fuel tank outlet and blocking the fuel flow. Check and see if there is a screen that plugs off the exit of the tank.
Yes I think there was white smoke after losing power.
   / JD 401A diesel loader looses rpm after about 3 hours runtime #5
My little tractor has a filter by the tank and another by the pump on the engine. Just an idea.
   / JD 401A diesel loader looses rpm after about 3 hours runtime #6
If air was restricted smoke would be black not white. White usually indicates water.
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2019 Ford F-150 XL (A50123)
2019 Ford F-150 XL...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
Pallet of Miscellaneous Heaters (A52384)
Pallet of...
