JD 400 Industrial Backhoe parts
   / JD 400 Industrial Backhoe parts #1
Peterc01
Australia
Jd400
Hi All
I recently purchased a jd400 backhoe and I'm wanting parts and advise on fixing the tacho/speedometer.
Its not working at all and would like to know if generally is it just a matter or replacing the cable or should i replace cable and tacho?
Also the only gauge that works is the temp gauge, Ive got a wiring diagram for the tractor but trying to make sense of it is hard to figure out, including how to get fuel gauge and all lights/buttons working.
I am after a supplier in or who will ship to Australia.
Other then the above its a great tractor which is build solid, its got a couple decent oil leaks on backhoe side of things which I think are ram seals and a leaking hose connector.
I recently did a full service including oil/diesel/hyd filters and oil, also flushed and cleaned radiator.
Any Info would be good.
   / JD 400 Industrial Backhoe parts #2
Normally the cable is the problem on a non-working tach.
   / JD 400 Industrial Backhoe parts #4
what you can do is to take the cable off the back of the tach and run the engine and see if the center cable spins if not replace cable and if it spins replace the tach and also the tachs are about $300.00 at least on mine from the dealer for my jd400
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
