JD 3720 cab noise
/ JD 3720 cab noise #1
DP Property
BelleRiver, Ontario
Kubota B7510, JD GT235, JD 757, JD Gator 850D, JD 3720 hi-spec cab on order
Just wondering if all the squeaky noise in the cab with every little bump I hit is normal in the 3000 cab series? I got the steering wheel squeak sorted out with a washer but the cab itself really makes lots of squeaky sounds on every little bump I hit. Kind of annoying on a machine that cost so much hard earned money.
/ JD 3720 cab noise #2
Hi,
Did you re-torque the cab mounting bolts as specified in the manual? I think it calls for that around the 15 or 20 hour mark.
Tom
/ JD 3720 cab noise #3
I have heard wiping a silicone based lubricant (spray on rag, then wipe on) on all the door seals will help some of the noise.
/ JD 3720 cab noise
Hi,
Tom
Hi Tom I did not know this have not read entire manual yet but I just hit 20 hours. Will look into this for sure.
/ JD 3720 cab noise
That would make sense also will look for a silicone based lubricant that won't damage the seals.
/ JD 3720 cab noise #6
Should not be having cab squeaks. Had JD 3720 and now 4520 but no cab squeaks. Try is isolate where the noise is. The door could be a common location and the door latch can be adjusted. Is is the mounting bolts? Something rubbing on the cab?
/ JD 3720 cab noise #7
No squeaks here ----- 3720 cab tractor bought new in 2007. Wish I could help but the aforementioned suggestions sound like good ideas.
I should add that my door latches are adjusted such that the doors have to be slammed/pushed hard to latch.
/ JD 3720 cab noise #8
My steering wheel squeaked badly, but that's since been fixed under warranty. Yours however sounds like door seals, but that's just a guess. You might see if tightening the latches helps. My cab is so air tight that I have to have the left door open before the right door will latch.
//greg//
/ JD 3720 cab noise #9
//greg//
Yep, same here. :thumbsup:
/ JD 3720 cab noise
I have 20 hours on the machine now but seriously out of all the machines I have that hour meter is fast I am sure of it! I did the door test you guys just made me head out in the dark to the new shelter for the tractor and same thing here. I had to open the left door could not make the right door latch for the life of me.
Not sure where the cab bolts are that I guess should be retightend at 20 hours but will check the manual tonight. My seals all seem good cab just squeaks I think more at higher speeds when you hit bumps. This machine is new even checked the serial number on the motor the motor was built only 2 months ago. It can't be anything major maybe I am being to critical.
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
AGROTK YC-32G Horizontal Band Saw (A60463)
AGROTK YC-32G...
SANDBAG ATTACHMENT (A60736)
SANDBAG ATTACHMENT...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
1005 (A61166)
1005 (A61166)
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
