JD 35C steering issue
   / JD 35C steering issue #1
zorro700
Mine is a 350C. I replaced all the oil except the hydrolics for the blade. It still will not turn left. If you pull back on the right lever it turns right, if you pull back on the left lever it keeps going straight unless you are backing up a hill or pushing a little dirt. If I pull back on both levers the dozer will stop. It will spin the tracks in 2nd gear and stall it if you get a good load in front of it and pick up the blade (I'm clearing trees right now). My question is that from what I've read I need a new "brake band". Do you replace them from the top under the seat or from the side by taking the track off, the sprocket off, then the final drive housing and come in from that way? If I come in from the top it looks like I'll have to take the roll bars off, the fuel tank off and the battery box and blade hydrolic box off and that means take a WHOLE bunch of hydrolic lines off. Anyways what is the easiest procedure for replacing a brake band?
Thanks for the help in advance guys.
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
78in Screening Bucket Skid Steer Attachment (A51691)
78in Screening...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
