JD 348 Knotter problem
   / JD 348 Knotter problem #1
Lucerne
Australia
MF6475
I have a JD 348 Baler where I can't fix a problem with one knotter. It ties a knot but is not strong enough to hold when the bale comes out of the baler (knot undoes). I've tried nearly everything from billhook tension, twine holder tension, replacing twine holder & disc, replacing knife arm & varying it's clearance from the billhook (as the manual suggests). What I have found (by chance)that decreases it's occurrence is when the twine disc position is way out of the correct spot. But hasn't stopped it completely. Please help.
   / JD 348 Knotter problem #2
Do you have an operators manual? Have you checked for correct timing of needles to plungerhead?? Are needles coming up into knotter high enough? I'm fairly decent at repairing a wire baler but have limited experience on a twine knotter. It's unfortunate that JD doesn't offer a knotter tech manual unlike NH.
   / JD 348 Knotter problem #3
I had a similar problem with mine and used a NH tech manual (same knotter) to fix it. Mine the needle was too far and the twine disc was somehow making a small nick in the twine leading to breakage. I adjusted the wiper a bit too because the knot would hang and break some of the time.
   / JD 348 Knotter problem #4
I'm curious. Are the knotters the same or just similar? Will the billhooks or twine discs interchange on JD & NH? I know JD & NH wire twister hooks won't interchange.
   / JD 348 Knotter problem #5
I priced a new knotter assembly for a JD 336 baler last year. IIRC - it was $1,200 and change!!! :shocked:
After I settled down a bit... I asked myself a couple of questions - how much is 2 weeks or a month of aggravation worth? And, if you're in the middle of getting your hay done and the baler goes down - how much is that worth?
Never shelled out the money cause the problem was minor - twine holder tension setting.
But, I think I would if it really came down to it....
AKfish
   / JD 348 Knotter problem #6
Knotters do wear out, but a brand new 1200$ knotter will not perform any better unless the right baler mechanic sets it up. Not many left who can setup a square baler.
Re knotters, there are only 2 basic designs. One leaves a cut tail, one doesn't. I've used both and they both work. The JD and NH both use the same type of knotter, MF uses the other type (or used too, not sure now they have the Hesston inlines)
Thanks Tx Jim & slowzuki, I'll check the needle timing but why isn't the other knotter playing up as both needles are exactly set up the same. It wouldn't be something to do with the billhook not holding the ends of the twine long enough to get a stronger knot formed.
   / JD 348 Knotter problem #8
Needle timing has nothing to do with it. You didn't say whether the knot was breaking or coming undone. If its coming apart, is it too loose just after a tie or does it look OK until it sees tension from a downstream pickup or unloading?
If that's the case, then a loose knot is cause by low bale density or a damaged billhook tongue. If the knot looks OK after the tie but can be pulled apart aftr the fact, then the twine may be doubled back into the knot. That's caused by the billhook tongue closing on top of the twine. Look for a bad (worn) roller on the knife arm or a bent upper end of the knife arm that prevents the twine from being guided over the billhook tongue.
The twine or knot isn't breaking, the knot is just undoing when tension is put on it when the bale comes out of the chamber. One or both ends seem to get doubled up (looped) in the knot. Occurs about one in 20 bales.:confused:
Thanks for the reply zzvyb6. That's what I thought initially when I replaced the knife arm with a new one. The roller looks fine. But still no difference. With the roller, does it matter what way around it goes on ?
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
2018 Kubota RTV-X1100C 4x4 Diesel Utility Cart (A51691)
2018 Kubota...
MachPro MP15Pro Mini Excavator, NEW! (A52384)
MachPro MP15Pro...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2022 Kubota B2601 (A50123)
2022 Kubota B2601...
