JD 345 stumbles and dies
   / JD 345 stumbles and dies #1
woodmeistera1
JD 345
I recently purchased a nice used JD 345 with an 18hp Kawasaki LQ v-twin motor. Only used a couple times for 10 minutes or so each time and it ran great. But a couple days ago I ran it and then let it idle for about a minute and it suddenly stumbled and died. It restarted but blew out a puff of gray smoke and smelled like raw gas. I pulled the spark plugs and noticed they were black and also smelled like gas. The piston was also wet when viewed with a flashlight. I pulled off the carb and took off the float bowl to see if the needle and seat were marred or clogged and found no noticeable problems. Cleaned everthing up and put it back together. It seemed to run fine but then stumbled, sputtered and died. Could the float level be too high or could the needle and seat have microscopic imperfections causing the excess fuel flow? What else could cause the over-rich mixture after idling a while? Any help would be appreciated.
   / JD 345 stumbles and dies #2
Dirty air filter, misadjusted choke. Sorry I can't be more help.
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
